Date/Time: Sun, 16 Mar 2025 15:12:38 +0000
Combine DOM columns
View Count: 1930
[2019-10-08 19:01:44]
User495158 - Posts: 108
Hello!
Would it be possible to add a feature for DOM - to combine the cumulative last size column with the current traded total volume column?
That way DOM window width could be further reduced. This feature is available for X Trader. Please see the screenshot.
imageXtrader.jpg / V - Attached On 2019-10-08 19:01:35 UTC - Size: 91.65 KB - 563 views
[2019-10-08 19:46:58]
T44 - Posts: 363
I'd find this helpful too (assuming it doesn't infringe one of the many TT patents!)
[2019-10-11 01:56:46]
User76183 - Posts: 69
+1
[2019-11-23 16:52:20]
NotIll - Posts: 118
+1.618
[2020-01-03 23:33:16]
John - SC Support - Posts: 38678
In the next pre-release (v 2033), there will be a new option to display the Cumulative Last Size in the Current Traded Total Volume column at the current price. The option is located on the Chart DOM Settings page (Trade >> Chart DOM Settings) and is called Display Cumulative Last Size in the Current Traded Total Volume.
The color settings that apply to the Cumulative Last Size are used for the display of these numbers in the Current Traded Total Volume, so you can easily distinguish it by adjusting the colors for the text and background to be different from the Current Traded Total Volume text color.
We will be updating the documentation next week for this.
[2020-01-04 00:00:42]
User735587 - Posts: 21
Can you please add a color for LTQ (Display Cumulative Last Size) when it doesnt uptick nor downticks ?
At the current moment there are only 2 colors to set up :
- up tick
- down tick
Date Time Of Last Edit: 2020-01-04 00:04:17
[2022-08-17 14:25:07]
User952036 - Posts: 16
I did the LTQ of the SC yesterday as in Daytradr, so it only shows blue or red when there is a price change/first hit in the next price. The result in SC was not satisfactory: the sequence of the LTQ is so fast that hardly any color can be perceived. As in Daytradr, a time delay for the color is missing.
Can you add a time delay for the backgroundcolor of the LTQ when the price ticks up or ticks down, so that i can see a white backgroundcolor when the price is hit two times in a row? I know this standard from other platforms and miss it.
Date Time Of Last Edit: 2022-08-17 14:29:50
[2022-08-17 15:18:30]
There are coloring options available for the Cumulative Last Size such that it can be a different color when the trade is at the same Side and Price. Refer to the following and the 3 items below it:
Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Chart DOM Cumulative Last Size Bid Trade Same Price and Side Background Color
