Date/Time: Wed, 12 Mar 2025 05:16:46 +0000
Chart Far Right Side Spacing
View Count: 2812
[2019-10-08 18:22:15] |
ycomp - Posts: 321 |
(see attached) How can I set the bottom chart like the first chart - having a gap between the price and the edge of the window?
[2019-10-08 20:22:50] |
Refer to: Working With Charts: Right Side Fill Space Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-10-09 06:38:35] |
thanks, I'm familiar with fill space - that would be the part to the left of the prices on the chart. What I'm asking about is the space to the right - the padding between the numbers and the edge of the window. In the attached image, the top chart has significant padding there but the bottom chart has barely any. Date Time Of Last Edit: 2019-10-09 06:39:28
[2019-10-09 07:03:11] |
What you are referring to is automatically managed and cannot be controlled. If you select Chart >> Reload and Recalculate you would probably notice the space between the price scale, and the right edge becomes less in that top chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
