Date/Time: Sun, 02 Feb 2025 20:48:53 +0000
control bar icon backup
View Count: 616
[2019-10-08 15:50:55] |
User873130 - Posts: 45 |
Hi What is the name of file that needs to be copy and pasted into another installation folder so I can retain the icons created for control bar group? |
[2019-10-08 16:29:58] |
The file sierra3.cfg which is located in the main Sierra Chart installation folder contains the information for the control bar configurations. But, if you have applied an image to your control bar, then make sure you also have a copy of that image. The default location for control bar images is in SierraChart\Graphics\Buttons, where SierraChart is your main Sierra Chart installation folder. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
