Date/Time: Sun, 02 Feb 2025 20:36:15 +0000
Repetitive message in Service Log
View Count: 535
[2019-10-08 08:27:03] |
User7097040000 - Posts: 13 |
It seemed to be a problem with the Trade Activity Log in the past and this annoying message shows up every time I run SC since then: Trade Activity file unexpected condition. Did not find FIELD_CODE_BEGIN_RECORD when expected. Field code read: 0. D:\SierraChart\TradeActivityLogs\TradeActivityLog_2019-07-26_UTC.data | 2019-10-07 05:57:03.246 * How can I get rid of it? Thanks in advance |
[2019-10-08 09:56:28] |
There is a problem with this file: . D:\SierraChart\TradeActivityLogs\TradeActivityLog_2019-07-26_UTC.data We recommend just deleting it. You can keep Sierra Chart running when you delete it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-08 09:56:36
