Date/Time: Sun, 02 Feb 2025 20:41:25 +0000
[User Discussion] - Pulling Stacking apparent error
View Count: 630
[2019-10-08 06:55:43] |
User234172 - Posts: 44 |
CQG demo data. MJNK symbol Bid went from 1244 to 1042 = 202 lots pulled from bid. At the same time, Pulling/Stacking data for that price went from +243 to -6767 = implied 7,010 lots pulled from the bid at that price. It was not the inside bid. Nothing traded at that bid. |
[2019-10-08 07:18:32] |
We are fully declining support for this. Any type of issues with this functionality would be with the underlying data feed. We cannot help you. For more information, refer to: CQG Trading Platform Service: CQG Market Depth Data The problem you saw was definitely not the result of Sierra Chart doing anything incorrectly. It is the data feed! This really only shows you cannot rely upon pulling and stacking data when using CQG. This is just further confirmation of what we already suspected. The problem is, we have no all their alternative for you. If this was a CME symbol, then we would recommend using the Sierra Chart data feeds. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-08 07:51:35
