Date/Time: Sun, 02 Feb 2025 20:35:15 +0000
Tick data export 2 years
View Count: 724
[2019-10-08 01:05:45] |
User298669 - Posts: 2 |
Hi SC team, Given the setup I have with my account, do you recon will be possible for me to get 1 year of tick by tick data for SP500 futures? My market data are part of the service offered bu you through denali data feed. Just wondering if there is a way to download a full year of tick data split by buy and sell orders. Thanks |
[2019-10-08 02:48:58] |
Yes this is fully supported. Refer to: Exporting and Importing Intraday Data Files Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
