Date/Time: Sun, 02 Feb 2025 19:07:28 +0000
[User Discussion] - Saving chart windows positions?
View Count: 1728
[2019-10-07 22:15:14] |
User132748 - Posts: 159 |
Hey, I work in 3 different places having different screen setups. Is it possible to save the configuration of chart windows positioning and sizes so it can be loaded dependant on current screens setup? Rearraning the charts everytime is very painful. Of course I can save whole chartbook but any change or note will stay in given chartbook. Thanks |
[2019-10-07 22:28:12] |
Mack - Posts: 83 |
I have a single screen and I work with multiple Chartbooks. Sierra will remember how you arrange your windows if you save that Chartbook, and load it back later. In addition, I have added the "tile vertically" button to my control bar. With 4 charts in a chartbook, you get a 2x2 square which is kind of neat. In addition, Sierra orders the windows based on the tab position in the Chartbook, which makes organizing easier. On Mac I have this tool called "Moom" to easily resize (Mac) windows. I guess you could detach a Chart, and use a similar windows tool to position it in a certain way. (like 1/3 of the screen i.e.) |
[2019-10-07 22:29:51] |
Mack - Posts: 83 |
(afaik, what you want is not possible right now btw)
