Date/Time: Sun, 02 Feb 2025 20:51:01 +0000
[User Discussion] - DOM graphic
View Count: 619
[2019-10-07 20:11:03]
Snehil - Posts: 3
Despite changing the graphics like bid and ask coloumn colors from the graphic center nothing is changing in the DOM
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=32032
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=32033
[2019-10-08 02:55:57]
You need to use Global Settings >> Graphics Settings and make your changes there.
Refer to the following regarding when Chart specific settings are used versus global settings:
Graphics Settings: Use Global Graphics Settings Instead of These Settings
[2019-10-08 03:29:41]
Snehil - Posts: 3
I am changing the colors setting from the global settings but nothing is happening
Private File
