Date/Time: Sun, 02 Feb 2025 19:11:01 +0000
using my services?
View Count: 605
[2019-10-07 17:30:53]
david135 - Posts: 3
Hello, when i log in to sierra charts i see this [SIM] at the top of the window so does it mean i am not using the service i payed for? Am i using the simulator? Also i have two desktop icons "sierra chart" and "sierra chart 64" what is the difference?
and if i am using oanda metatrader for Forex do i need to pay for any data feed?
Thank you,
[2019-10-08 01:18:39]
The [SIM] at the top of the window means means Sierra Chart is in Trade Simulation Mode. This can be enabled or disabled. Refer to the information here:
Overview of Trading: Difference between Simulated and Non-Simulated Trading Modes
The icons are referencing the 32-bit and 64-bit (respectively) versions of Sierra Chart. You should use the 64-bit version unless there is some reason you cannot.
You do not need to pay anything more for a data feed. This is included:
Sierra Chart Real Time and Historical Forex and CFD Data Service
Date Time Of Last Edit: 2019-10-08 01:19:36
