Date/Time: Mon, 06 May 2024 01:26:14 +0000
new version 1997
View Count: 587
[2019-10-07 15:32:12] |
User223358 - Posts: 6 |
Hi, I have installed the version 1971 back in august 2019. I see a new version to upgrade, do I absolutely need to upgrade or not? If yes, can I keep all my settings ? Please just tell me how can I do this (keep my settings)? Many thanks. |
[2019-10-07 16:27:59] |
No you do not need to update but if you do update all the settings will remain. Refer to: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
