Date/Time: Mon, 06 May 2024 07:02:10 +0000
Order Allocation to Trade Accounts
View Count: 541
[2019-10-07 13:02:19] |
patrader - Posts: 92 |
Using CQG FIX Trading. I have two accounts under the same CGQ log-in. When using Order Allocation to Trade Accounts it brings up a trade confirmations window even though I have unchecked all confirmations. What to do?
[2019-10-07 13:21:31] |
This is a safety feature, not being able to disable the confirmation window. Maybe we will take that out, but right now it exists.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-07 13:21:43
[2019-10-07 14:09:27] |
Can you make it an option please? Sierra is known for its flexibility and, just like for single accounts, the trader should be able to choose. Thank you.
