Date/Time: Sun, 02 Feb 2025 20:38:03 +0000
two installation of Sierra, chartbook doesn't work
View Count: 630
[2019-10-07 08:26:25]
User811622 - Posts: 38
I have two Sierra installations, main one is in c:\sierachart and the new installation (2nd) is in c:\sierrachart2. I copied chart from c:\sierrachart\data to c:\sierrachart2\data folder. The chart contains default spreadsheet. When I open the chart on c:\sierrachart2, it doesn't work correct. Seems like all data from the spreadsheet is lost. And the chart looks weird. Please advise on how to resolve this issue.
[2019-10-07 11:24:04]
Mack - Posts: 83
Hi, did you update your "Data Files Folder" in General Settings?
[2019-10-07 12:33:02]
User907968 - Posts: 825
did you copy the spreadsheet file across (.scss)?
[2019-10-08 02:35:40]
Make sure you have copied the spreadsheet files as well. These have an SCSS file extension.
[2019-10-08 03:20:05]
It worked after copying spreadsheet as well.
