Date/Time: Sun, 24 Nov 2024 23:11:41 +0000
Time and Sales color settings
View Count: 1114
[2013-12-16 14:13:50] |
VF56002 - Posts: 27 |
I noticed you have changed color settings for Time and Sales window. Is there a possibility to set color "globally" so I don't have to always change it back to the old style red-green version manually each time ? Thank you
[2013-12-16 16:43:16] |
There are no global settings for the Time and Sales window but you can duplicate charts to get the same settings for an existing chart. Here are the instructions: http://www.sierrachart.com/index.php?l=doc/doc_ChartMenu.html#DuplicateChart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
