Date/Time: Mon, 06 May 2024 10:35:30 +0000
Time Error
View Count: 659
[2019-10-06 20:26:29] |
Ron009 - Posts: 15 |
I just started getting the following error message: Error setting System Date-Time. Windows error code 1314:A required privilege is not help by the client. |
[2019-10-06 20:29:09] |
This is explained in this section here: Global Settings Menu: Set System Date-Time from Server (Global Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
