Date/Time: Mon, 06 May 2024 09:38:14 +0000
rithmic connection: unknown message type 603
View Count: 551
[2019-10-06 19:38:10] |
uM8137 - Posts: 180 |
When I connected to rithmic just now, I got the following warning message in the SC log: Rithmic Trading | Message from server: Received unknown message type from DTC client. Type = 603 | 2019-10-06 14:26:01.699 Is SC (v1982; update: also happens on v1996, the latest) up to date with the rithmic API? Date Time Of Last Edit: 2019-10-06 19:43:15
[2019-10-06 20:16:40] |
You can safely ignore that message.
