Date/Time: Sun, 02 Feb 2025 20:41:43 +0000
POC on TPO
View Count: 614
[2019-10-06 17:21:24] |
User232042 - Posts: 35 |
Hello, I was wondering if it is possible to have both the Time POC & the Volume POC highlighted within the same study. For example the TPOC letters would be colored and the VPOC would just be a line extended. Ill post a picture of what I have below. Thanks for your time. http://www.sierrachart.com/image.php?Image=1570382274603.png |
[2019-10-08 20:03:40] |
Yes, this is possible. Just turn on the display of the POC for the the TPO and the for the VbP within their respective studies. Set the display of the POCs as you desire.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-08 20:04:13
