Date/Time: Thu, 06 Feb 2025 22:55:48 +0000
CountDown Timer study - issue with horizontal position
View Count: 954
[2019-10-06 15:54:59] |
User401662 - Posts: 16 |
Hi, The CountDown Timer study seems to have a problem with the horizontal position. Since version 9, the number cannot appear on the right of the last candlestick like before. "Initial Horizontal Position From Left (1-150)" parameter seems useless as the number always appear on the left side of the chart. It cannot move horizontally. I attached the chart and the study parameters that I'm using. Thanks. |
parameters.png / V - Attached On 2019-10-06 15:52:40 UTC - Size: 65.68 KB - 269 views Replay 1.00X F.US.MNQZ19 2000 Volume #2 2019-10-06 17_51_.png / V - Attached On 2019-10-06 15:52:58 UTC - Size: 35.64 KB - 292 views |
[2019-10-07 06:05:23] |
You have to manually move it. As documented here: Countdown Timer: Moving Countdown Timer Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-07 06:05:34
[2020-05-14 18:50:10] |
mittalpa - Posts: 28 |
So cool.. you guys rock!
