Date/Time: Mon, 06 May 2024 10:03:41 +0000
SetACSToolEnable not working since version 9
View Count: 562
[2019-10-06 10:04:51] |
User401662 - Posts: 16 |
Hi, It seems the function SetACSToolEnable has been replaced with something else since version 9 and I am not able to build my study anymore (see the build output below).Please help. --------------------- -- Starting remote build of Custom Studies Source files: tradingManagement_test.cpp. 64-bit -- 11:49:57 Allow time for the server to compile the files and build the DLL. The remote build did not succeed. Result: tradingManagement_test.cpp: In function 'void scsf_EnterWithMaxStopLoss(SCStudyInterfaceRef)': tradingManagement_test.cpp:185:6: error: 'struct s_sc' has no member named 'SetACSToolEnable' sc.SetACSToolEnable(ACS_BUTTON_1, false); ^ tradingManagement_test.cpp:186:6: error: 'struct s_sc' has no member named 'SetACSToolEnable' sc.SetACSToolEnable(ACS_BUTTON_2, false); ^ tradingManagement_test.cpp:187:6: error: 'struct s_sc' has no member named 'SetACSToolEnable' sc.SetACSToolEnable(ACS_BUTTON_3, false); ^ tradingManagement_test.cpp:328:8: error: 'struct s_sc' has no member named 'SetACSToolEnable' sc.SetACSToolEnable(ACS_BUTTON_1, false); ^ tradingManagement_test.cpp:399:8: error: 'struct s_sc' has no member named 'SetACSToolEnable' sc.SetACSToolEnable(ACS_BUTTON_2, false); ^ tradingManagement_test.cpp:413:8: error: 'struct s_sc' has no member named 'SetACSToolEnable' sc.SetACSToolEnable(ACS_BUTTON_3, false); ^ tradingManagement_test.cpp: In function 'void scsf_EnterWithMaxStopLossAtHighOrLow(SCStudyInterfaceRef)': tradingManagement_test.cpp:676:6: error: 'struct s_sc' has no member named 'SetACSToolEnable' sc.SetACSToolEnable(ACS_BUTTON_1, false); ^ tradingManagement_test.cpp:677:6: error: 'struct s_sc' has no member named 'SetACSToolEnable' sc.SetACSToolEnable(ACS_BUTTON_2, false); ^ tradingManagement_test.cpp:678:6: error: 'struct s_sc' has no member named 'SetACSToolEnable' sc.SetACSToolEnable(ACS_BUTTON_3, false); ^ tradingManagement_test.cpp:885:8: error: 'struct s_sc' has no member named 'SetACSToolEnable' sc.SetACSToolEnable(ACS_BUTTON_1, false); ^ tradingManagement_test.cpp:969:8: error: 'struct s_sc' has no member named 'SetACSToolEnable' sc.SetACSToolEnable(ACS_BUTTON_2, false); ^ tradingManagement_test.cpp:983:8: error: 'struct s_sc' has no member named 'SetACSToolEnable' sc.SetACSToolEnable(ACS_BUTTON_3, false); ^ tradingManagement_test.cpp: In function 'void scsf_EnterWithMaxStopLossAtHighOrLowV2Backup(SCStudyInterfaceRef)': tradingManagement_test.cpp:1351:6: error: 'struct s_sc' has no member named 'SetACSToolEnable' sc.SetACSToolEnable(ACS_BUTTON_1, false); ^ tradingManagement_test.cpp:1352:6: error: 'struct s_sc' has no member named 'SetACSToolEnable' sc.SetACSToolEnable(ACS_BUTTON_2, false); ^ tradingManagement_test.cpp:1353:6: error: 'struct s_sc' has no member named 'SetACSToolEnable' sc.SetACSToolEnable(ACS_BUTTON_3, false); ^ tradingManagement_test.cpp:1560:8: error: 'struct s_sc' has no member named 'SetACSToolEnable' sc.SetACSToolEnable(ACS_BUTTON_1, false); ^ tradingManagement_test.cpp:1644:8: error: 'struct s_sc' has no member named 'SetACSToolEnable' sc.SetACSToolEnable(ACS_BUTTON_2, false); ^ tradingManagement_test.cpp:1658:8: error: 'struct s_sc' has no member named 'SetACSToolEnable' sc.SetACSToolEnable(ACS_BUTTON_3, false); ^ tradingManagement_test.cpp: In function 'void scsf_EnterWithMaxStopLossAtHighOrLowV2(SCStudyInterfaceRef)': tradingManagement_test.cpp:2151:6: error: 'struct s_sc' has no member named 'SetACSToolEnable' sc.SetACSToolEnable(ACS_BUTTON_1, false); ^ tradingManagement_test.cpp:2152:6: error: 'struct s_sc' has no member named 'SetACSToolEnable' sc.SetACSToolEnable(ACS_BUTTON_2, false); ^ tradingManagement_test.cpp:2153:6: error: 'struct s_sc' has no member named 'SetACSToolEnable' sc.SetACSToolEnable(ACS_BUTTON_3, false); ^ tradingManagement_test.cpp:2579:8: error: 'struct s_sc' has no member named 'SetACSToolEnable' sc.SetACSToolEnable(ACS_BUTTON_1, false); ^ tradingManagement_test.cpp:2678:8: error: 'struct s_sc' has no member named 'SetACSToolEnable' sc.SetACSToolEnable(ACS_BUTTON_1, false); ^ tradingManagement_test.cpp:2693:7: error: 'struct s_sc' has no member named 'SetACSToolEnable' sc.SetACSToolEnable(ACS_BUTTON_3, false); ^ tradingManagement_test.cpp: In function 'void scsf_EnterWithMaxStopLossAtHighOrLowWithThreePortions(SCStudyInterfaceRef)': tradingManagement_test.cpp:3158:6: error: 'struct s_sc' has no member named 'SetACSToolEnable' sc.SetACSToolEnable(ACS_BUTTON_1, false); ^ tradingManagement_test.cpp:3159:6: error: 'struct s_sc' has no member named 'SetACSToolEnable' sc.SetACSToolEnable(ACS_BUTTON_2, false); |
[2019-10-06 10:15:16] |
The new name is sc.SetCustomStudyControlBarButtonEnable
[2019-10-06 11:22:26] |
Thank you.
