Date/Time: Sun, 02 Feb 2025 18:49:47 +0000
Linear
View Count: 571
[2019-10-05 00:19:32] |
John Ara - Posts: 125 |
Please let me know if I can have different markets in one window when they are showing in linear (line on close) mode? Thank you. |
[2019-10-08 01:40:12] |
Yes, you can have multiple symbols in one window that are set to Line on Close. Just use the Add Additional Symbol study and be sure to set the Scale to Independent. Refer to the following for the Add Additional Symbol study: Add Additional Symbol Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
