Date/Time: Wed, 16 Sep 2026 19:42:38 +0000
Multibroker Account
View Count: 2551
[2019-10-04 23:07:57]
User94606 - Posts: 327
What is the best way to setup a multi broker account in Sierra Chart? I am currently using Interactive Brokers and Sierra Chart's data feed. I would like to open a second brokerage account with AMPFutures. Can I use the same Sierra Chart instance and toggle between 2 brokerage accounts? or do I need to run a separate instance of Sierra Chart with a different Data/Trade Service configuration?
[2019-10-05 05:51:07]
See:
Using Multiple Data and Trading Services at the Same Time
[2019-10-07 12:40:46]
Can you confirm if this is the best option is to run a 2nd instance of Sierra Chart and configure the Data/Trade Service for CQG. I will need to recreate all existing chartbooks to map to the new CQG symbols.
[2019-10-08 02:33:47]
Yes that is the right way to do it.
Refer to help topic 15 to copy files to another instance:
Transferring Sierra Chart Settings and Data From Existing Installation to New Installation
To convert symbols, use this new command:
Edit Menu: Edit >> Translate Symbols To Current Service
You do not have to re-create any Chartbooks.
Date Time Of Last Edit: 2019-10-08 02:34:33
[2019-10-08 05:33:22]
Are you saying that I can use the same chartbooks from instance #1 (using Sierra Chart as the data provider) and CQG running on instance #2? I just need to run in instance #2, Edit -> Translate Symbols to Current Service?
[2019-10-08 06:42:18]
User164231 - Posts: 281
Hi I am using IB and would like to add TOS. If I understand correctly I have to create another instance for TOS. But I cannot select TOS at the top column when I opt for another instance. What did I do wrong?
imageNew Instance.jpg / V - Attached On 2019-10-08 06:39:01 UTC - Size: 122.96 KB - 393 views
[2019-10-08 07:23:36]
In these cases you definitely cannot use File >> New Instance.
You have to use the procedure here:
And you have to install two additional instances.
And Edit >> Translate Symbols to Current Service is what you need to use after copying a Chartbook to another instance and opening it.
Date Time Of Last Edit: 2019-10-08 07:24:57
