Date/Time: Thu, 02 May 2024 11:13:08 +0000
[Locked] - bids offers closes to price on market depth historical graph
View Count: 9312
[2019-10-20 22:58:06] |
Sundowned - Posts: 7 |
+1
[2019-10-20 23:18:30] |
@sstfrederik - Posts: 403 |
+1
[2019-10-20 23:21:30] |
User450950 - Posts: 9 |
+1
[2019-10-20 23:53:12] |
User918738 - Posts: 31 |
+1
[2019-10-21 00:05:55] |
User935626 - Posts: 7 |
Appreciate SC if you fix this.
[2019-10-21 01:35:59] |
User223137 - Posts: 3 |
+1
[2019-10-21 03:12:14] |
User234172 - Posts: 44 |
+1
[2019-10-21 10:04:09] |
User447052 - Posts: 6 |
+1
[2019-10-21 10:17:51] |
oicur12 - Posts: 17 |
+1
[2019-10-23 16:59:34] |
We will work on getting the additional levels of implied depth, no more than one or two, merged in with the standard market depth in the next couple of weeks with the Sierra Chart CME Group data feeds.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-23 17:00:27
[2019-10-23 17:21:13] |
zippyzip - Posts: 293 |
Thank you guys , we appreciate the hard work
[2019-11-01 01:17:23] |
Hi SC, Question: does the "Sierra Chart real time" data service have the different levels represented correctly as described in this above request chain? I know you are working on the correction in the Denali data service. Thanks in advance! Date Time Of Last Edit: 2019-11-01 02:18:55
[2019-11-01 04:50:26] |
User541156 - Posts: 67 |
Putting my money where my mouth is I have moved to Denali this month. Now hoping for quick resolution of implied depth issue (to be same as everyone else on the market) |
[2019-11-01 11:49:58] |
you made a wise choice 541156 , denali is the future of SC and its going to be great !!!
[2019-11-01 12:44:23] |
BenjFlame - Posts: 305 |
What about the full real time SC feed?
[2019-11-02 17:19:24] |
We have completed the development to fully merge in the implied depth beyond the first level, for all the additional levels provided by the exchange whatever number of levels there are. They say there only two levels but maybe there are three. This will be tested, this coming week. And should be released the following week. This will be available with the Denali Exchange data feed and the Sierra Chart Exchange Data Feed. We hope that answers the remaining questions. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-02 17:19:49
[2019-11-02 20:10:22] |
USER0007 - Posts: 21 |
Thank you very much!
[2019-11-03 00:39:41] |
User920967 - Posts: 62 |
Thank you SC, i will be making my denali switch this month.
[2019-11-12 18:47:19] |
User852559 - Posts: 40 |
Any update on the release of this functionality? Thanks.
[2019-11-12 19:09:56] |
It has been released on one of our four servers for CBOT. We are just doing it incrementally. We did find a problem with it initially and fixed that over the weekend.
[2019-11-18 10:18:25] |
RogerT - Posts: 10 |
Hi SC, how's the rollout to all four servers progressing ? Do you have a target date for completion ?
[2019-11-18 13:40:08] |
9710276 - Posts: 24 |
Yes; do you have an ETA for when this will be implemented for CL, GC and many of the future's equity markets -- such as ES, YM, RTY, etc? I haven't been able to use my Denali feed this month and am not sure if I should keep the subscription going or just let it cancel for now and pick it up later (if it is going to be a while). I was under the impression the fix would be around 2 or 3 weeks, initially. Thanks! |
[2019-11-20 11:20:08] |
User374449 - Posts: 1 |
is the Denali data feed fixed yet ?
[2019-11-21 15:40:28] |
Tooth Fairy - Posts: 79 |
Probably not. Server 2,my main server, level 2-3 are still off significantly from CQG. My trading using depth of market is pretty handicappped by forced CQG switching. Thank you Sierra.
[2019-11-21 16:13:01] |
samual sprat - Posts: 343 |
An update would be nice here
