Date/Time: Sun, 24 Nov 2024 22:39:58 +0000
[User Discussion] - Using Sierra Chart on a Table
View Count: 1230
[2013-12-16 02:48:10]
a266199 - Posts: 6
Hi SC Support,
Would it be possible to provide a list of tablets that will support the use of SC on them?
I'm a little technically challenged when it comes to specs, etc...and was hoping someone could post a list of approved tablets/hybrids that SC would run properly on.
Any information is appreciated.
[2013-12-16 05:13:58]
vegasfoster - Posts: 444
Your primary choices for Windows tablets are Atom or I5. In lieu of response from someone who has one, looking at CPU benchmarks, an Atom seems comparable to my slow computer, which means it will work ok if you are only loading a single chart. Any more than that and I'm really thinkin you want to go I5 with 4-8 gigs of ram, and at least a 128 gig hard drive.
