Date/Time: Sun, 02 Feb 2025 20:12:39 +0000
Chart values do not appear when I am using chart values / crosshairs
View Count: 580
[2019-10-04 16:33:52]
User424274 - Posts: 6
I am using the crosshairs and when I go to say a bar 20 minutes ago and click on it, I do not get the chart values to popup. The only chart values that I get are the current ones. What can I do?
Thank you,
Larry
[2019-10-04 16:58:31]
John - SC Support - Posts: 37656
Make sure you are using the Tool Values Window and not the Chart Values Window. Refer to the information here for the Tool Values Window:
Window, CB and CW Menus: Tool Values Window (Window)
Also be aware of the Compact Tool Values Window. The information for it is in the section just below the above link.
[2019-10-04 18:28:50]
John,
Thank you for your response. I have read the information on the link that you sent. I made sure that I had the tools..chart value window enable, I went to the reset window. I still can't get any values to show up on any past bars.
Thank you,
Larry
[2019-10-04 18:39:09]
John,
My problem started with a download to a new computer. I am using the same settings on my new computer as my old one. The values shows in my old computer but not my new one.
Thank you,
Larry
[2019-10-04 20:16:57]
You stated
Just to make sure you are getting the right one - go to the pulldown for Window and select Tool Values Window.
Date Time Of Last Edit: 2019-10-04 21:02:39
