Date/Time: Sun, 02 Feb 2025 20:04:12 +0000
Study that shows Value Area Lines over time on the Chart?
View Count: 1101
[2019-10-04 08:04:58] |
ycomp - Posts: 321 |
Is there a Sierra Chart (Built-In or User Contributed) study that can display the Value Area lines on the chart over time? See attached, it is a screenshot from this video: https://youtu.be/h5k2vmxQQL0?t=536 Date Time Of Last Edit: 2019-10-04 08:06:36
2019-10-04_16-00-31-875.png / V - Attached On 2019-10-04 08:01:19 UTC - Size: 748.49 KB - 337 views |
[2019-10-04 08:27:07] |
User907968 - Posts: 825 |
Maybe this is what you need? Volume Value Area Lines |
[2019-10-04 12:08:06] |
I'm trying to figure it out with that study but: 1) would I have 2 use 2 sets of these indicators and set one to 70% and one to 100% ? 2) would there be any way to shade in the areas like in the screenshot? |
[2019-10-04 13:00:38] |
Ok 1) You can use more than one study to achieve the result you want, yes. 2) Yes - read this Chart Studies: Notes about Top and Bottom Draw Style Pairs & Chart Studies: Filling the Area Between Two Study Subgraphs within Different Studies I made a study collection that does something similar to what you want. |
Filled_Value.StdyCollct - Attached On 2019-10-04 13:00:22 UTC - Size: 46.61 KB - 396 views filled value.png / V - Attached On 2019-10-04 13:00:31 UTC - Size: 92.37 KB - 339 views |
[2019-10-04 13:05:33] |
thanks, I'll check it out this weekend
