Date/Time: Mon, 06 May 2024 04:35:26 +0000
How to use AND condition
View Count: 625
[2019-10-03 19:09:34] |
maddy91 - Posts: 11 |
In Alert based auto trading, i want to use AND for two studies. RSI and Bollinger Band 1. RSI Top Band Should be greater/above the Middle Band ID1.SG1(Top band), ID1,SG4(Middle Band) 2. Price should cross the top Bollinger band. ID2.SG1(Top band) 2nd Study is vice versa 1. RSI Top Band Should be Less.Below the Middle Band ID1.SG1(Top band), ID1,SG4(Middle Band) 2. Price should cross the Lower Bollinger band. ID2.SG3(Bottom band) How can i use both conditions in alert formula? I know i have to make multiple studies but can you please help in creating one? |
[2019-10-06 01:59:46] |
Refer to: https://www.sierrachart.com/index.php?page=doc/SpreadsheetFunctions.html#AND_Function Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
