Date/Time: Wed, 05 Feb 2025 10:54:38 +0000
Chart Trading - Trade Entry Process
View Count: 895
[2019-10-03 19:00:37]
User374751 - Posts: 40
Support Team,
Please seriously consider re-configuring the Chart Trading - Trade Entry process.
Please consider using Keyboard Key + Mouse Click combinations.
For example:
Ctrl + Left Click (Above the Ask)   Buy Stop Market @ selected price
Ctrl + Left Click (Below the Ask)   Buy Limit @ selected price
Alt + Left Click (Above the Bid)   Sell Limit @ selected price
Alt + Left Click (Below the Bid)   Sell Stop Market @ selected price
Shift + Left Click (Above the Ask)   Buy Stop-Limit @ selected price (stop is at selected price, limit is set by offset amount set in the Chart Trading settings
Shift + Left Click (Below the Bid)   Sell Stop-Limit @ selected price (stop is at selected price, limit is set by offset amount set in the Chart Trading settings
I understand that this is a feature request and may or may not be implemented. I also acknowledge the likelihood of no response to this request.
I do have question, however. Can this feature be programmed by a 3rd Party for my use?
[2019-10-03 20:21:36]
If you are not already aware of the Chart DOM have a look:
Chart Trading and the Chart DOM: Using the Chart DOM / Order Entry Ladder
[2019-10-03 20:35:03]
Support Team,
I am familiar with and I currently utilize the Chart DOM consistently.
However, Keyboard Key + Mouse Click programming would be my preference, so I can keep my eyes on the Chart. My preference in Right Fill Space creates too much distance for my eyes to travel once a trade entry is determined.
Thank you for your response. Please seriously consider this suggestion.
[2019-10-07 16:31:30]
What we can do is add a new Chart Setting that when enabled and when the Chart DOM is enabled on the chart and you hold the Control key for buy orders or the Alt key for sell orders, left click on the chart, the click will be considered as if it was in the buy or sell column of the Chart DOM respectively.
In this case the particular order action as set by the Trade >> Chart DOM Settings will be performed. So in other words it is like extending the Chart DOM functionality across the entire chart.
This is the best we can do.
Date Time Of Last Edit: 2019-10-07 16:32:29
[2019-10-07 17:34:32]
Support Team,
I greatly appreciate your consideration for my request.
I excitedly await the release of the version with the new Chart Trading technology.
Again, thank you very much.
[2019-10-07 17:37:57]
User90125 - Posts: 715
Would right click actions also be supported?
[2020-02-17 21:52:49]
Support Team,
I am writing to inquire the status of the new Chart Trade functionality that will utilize the Control key and the Alt key for trade entries.
Thank you
[2020-02-17 23:01:22]
This was added months ago. Here is the documentation for the relevant setting:
Chart Settings: Extend Chart DOM Across Entire Chart When Using Ctrl(Buy) / Shift(Sell) (Chart >> Chart Settings >> Trading menu)
We also see you are using Rithmic. We recommend that you use this service if you are performing live trading:
Sierra Chart / Trading Technologies Futures Order Routing Service
We can help you with the transition.
[2020-03-13 19:44:03]
Thank you for this new trade entry option.
I utilize it exclusively.
Date Time Of Last Edit: 2020-03-13 19:45:20
