Date/Time: Sun, 02 Feb 2025 19:47:41 +0000
TPO Chart Question
View Count: 564
[2019-10-03 16:26:22] |
User399080 - Posts: 5 |
My chart bounces with every tick on my TPO charts. I have downloaded and installed the current display driver and restarted my computer. Any solution? Thank you.
[2019-10-03 17:39:35] |
Set the Scale Range to Automatic. Refer to: Chart Scale and Scale Adjusting: Chart Bars or Studies Not Completely within View, Not Displayed, or Cut Off. Reset Scales. If you are using the OpenGL option, then disable that: https://www.sierrachart.com/index.php?page=doc/GraphicsSettings.html#UseOpenGLFforChartGraphics Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-03 17:39:50
