Date/Time: Sun, 02 Feb 2025 19:55:31 +0000
[Programming Help] - Spreadsheet AutoTrader - RSI Based - Formulas Question - Help
View Count: 1073
[2019-10-03 15:54:55] |
maddy91 - Posts: 11 |
I want the following four scenarios to work. 1. When RSI Crosses 70, generate a Buy Signal and use with the Attached Order. Used the following formula in Spreadsheet Buy Entry =AND(ABS($J$8)=0,CROSSFROMBELOW(AE3,AF3)) where AE is RSI Current Value and AF is Top Band(70) Sell Exit(Buy) Buy Entry =AND(ABS($J$8)<>0,CROSSFROMBELOW(AE3,AF3)) where AE is RSI Current Value and AF is Top Band(70) and J8 is position Quantity 2. When RSI Crosses 30, generate a Sell Signal and use with the Attached Order. Used the following formula in Spreadsheet Sell Entry =AND(ABS($J$8)=0,CROSSFROMBELOW(AE3,AG3)) where AE is RSI Current Value and AG is Lower Band(30) Sell Exit(Buy) Buy Entry =AND(ABS($J$8)<>0,CROSSFROMBELOW(AE3,AG3)) where AE is RSI Current Value and AG is Lower Band(70) and J8 is position Quantity What am i doing wrong,? when i use the same crossover formulas in alert for studies they work. I am not getting any buy sell orders alerts using this system. |
[2019-10-03 18:22:06] |
Sawtooth - Posts: 4164 |
The syntax is different for spreadsheet formulas: =CROSSFROMBELOW(AE3:AE4,AF3:AF4) https://www.sierrachart.com/index.php?page=doc/SpreadsheetFunctions.html#CROSSFROMABOVE_Function Also, it is best to use this method when referencing study output values: Working with Spreadsheets: References to Study Subgraph Columns when using the Spreadsheet Study |
