Date/Time: Sun, 02 Feb 2025 20:12:20 +0000
delta minimum and maximum
View Count: 1865
[2019-10-03 13:47:25]
User623367 - Posts: 6
good day, i want to know if imn sierra i get information about delta maximum, delta minimum, bid porcentage and ask porcentage per bar. usually that information appears in a box in the down part the chart. like appears in the next picture.
like appears in the attached file. thanks
imagedelta_minimo_y_maximo.png / V - Attached On 2019-10-03 13:45:54 UTC - Size: 139.55 KB - 647 views
imagedelta_minimo_y_maximo.png / V - Attached On 2019-10-03 13:46:23 UTC - Size: 139.55 KB - 366 views
[2019-10-03 21:13:17]
John - SC Support - Posts: 37656
Yes, that kind of data is available in a format similar to what you showed. In Sierra Chart these are the Numbers Bars Calculated Values studies. There are two of them, only because the number of options to display was too many for just one study.
You will find the documentation on these studies here, which includes a description of all the available options to display.
Numbers Bars: Displaying Numeric Information Below Numbers Bars
