Date/Time: Sun, 02 Feb 2025 20:08:43 +0000
OCO bracket order association lines
View Count: 1077
[2019-10-03 02:17:51] |
User684537 - Posts: 3 |
how do get OCO bracket order association lines or connection lines to show on the chart? IE: I want a line that connects my entry order with the attached stop loss and exit Thanks Nina |
[2019-10-04 16:52:01] |
Refer to the following setting: Global Trade Settings Windows: Order Association Lines (Global Settings >> Chart Trade Settings >> Working Orders >> Working Orders - Display) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
