Date/Time: Tue, 11 Mar 2025 22:45:31 +0000
Drawn Volume Profile Question
View Count: 622
[2019-10-02 22:40:52] |
User920967 - Posts: 62 |
I can only adjust a Drawn Volume Profile when Price in set to Chart Region 1 . . . .If price is set to any other chart region the Drawn Volume profile is NO LONGER adjustable (cannot even be selected). Can you please confirm whether this is the intended functionality or a simple bug? As always,thanks. |
[2019-10-03 08:11:54] |
This will be corrected in the next release.
[2019-10-03 12:49:32] |
Great news, thank you!
[2019-10-03 13:18:53] |
Let me also add that the day i flushed my lifetime Ninjatrader license down the toilet was a great day!
