Date/Time: Mon, 14 Sep 2026 21:02:32 +0000
[User Discussion] - HLC Bar Outline Option In Numbers Bars Study
View Count: 819
[2019-10-02 20:37:20]
Alberto Gauer - Posts: 121
Hi there.
Is it possible for you to add one more outline option in numbers bars study? As of now there is only candlestick option.
More specifically a HLC bar format. I don“t use candles, and using the close marker does not do a great job of representing a bar visually.
It would be very similar to how the candlestick outline is plotted, but it would plot only a vertical line in the middle of the number bars study (right where the bid and ask are separated by an "x", and where the wick is plotted in the candlestick outline) and a small horizontal line to the right side of the vertical line, representing the close (thus looking like a HLC bar).
[2019-10-04 14:57:27]
Another modification that Sierra Chart Engineering should do in next update (besides the HLC outline) is making the negative delta stay to left and positive delta to the right when we choose the volume to be displayed as delta in numbers bars study.
