Date/Time: Sun, 02 Feb 2025 20:11:53 +0000
Hidden Input with ACSIL
View Count: 748
[2019-10-02 17:40:26] |
User119530 - Posts: 15 |
I want to be able to save a value when the chartbook is saved but I don't want the input to be seen. I tried adding a SCInputRef and then setting the value if IsChartbookBeingSaved but when I go to load the chartbook the setting didn't save. If I give the input a name then it saves but then it's also seen. Thanks. |
[2019-10-02 18:14:28] |
I was able to get a hidden input to save but couldn't use an sc.Input index over 40.
[2019-10-02 19:57:34] |
You really should use this ACSIL member: ACSIL Interface Members - Variables and Arrays: sc.StorageBlock Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
