Date/Time: Sun, 02 Feb 2025 19:54:08 +0000
Chart DOM
View Count: 565
[2019-10-02 16:26:03]
User710679 - Posts: 43
hi,
i have a question. I have my chart with the DOM. I have the scale set it as X & Y Constant Relationship. THe issue is that everytime the markets ticks up or down, the whole Y axis moves up or down with it. Is there any way to make it still and avoid that move?
thanks
[2019-10-02 20:16:44]
Yes, since this is a Constant Range scale, just change the Constant Range Scale Mode to Manual. You will the information on this here:
Chart Scale and Scale Adjusting: Constant Range Scale Modes >> Manual Mode
