Date/Time: Sun, 02 Feb 2025 19:53:15 +0000
Price changes bar
View Count: 591
[2019-10-02 16:03:55] |
bskogz12 - Posts: 38 |
Good Afternoon, my favorite bar is 'Price changes per Bar' the draw back on this feature is when you click 'new bar on session start' then you get a partial bar at the EOD that often throws off my studies. i am wondering if you can come up with a similar study with one little difference.... Total price change divided by x....or likely Total daily price change divided by x So we can split the day up in say 10 spreads...if there are 2200 price changes then each bar will have 220 prices changes. This might have complications for a program the is feeding in real time Also if this is something i can create on my own let me know. |
[2019-10-02 16:21:28] |
You can create your own custom bar types. Refer to: ACSIL Interface - Custom Chart Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
