Date/Time: Sun, 02 Feb 2025 17:59:22 +0000
Question about remote help setting up Sierra Charts
View Count: 576
[2019-10-02 03:09:46] |
Lavorris WHITE - Posts: 12 |
Hello I'm reaching out to see if it's possible to receive help in setting up my Sierra Foot print Charts because I have no clue how to go about doing it Im new to this and the layout on here looks too complicated to set up..also who would I need to contact to purchase package #5 Thanks |
[2019-10-02 15:45:16] |
To get started with a package, you just need to go to the following page (login with your Sierra Chart Username and Password if necessary) and select the package you want for your account: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#AvailableServices If you need to add funds to your account, then you can do that on this page: https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit In terms of Numbers Bars, the following link will download an example chartbook that has the Numbers Bars already setup on it. It should help get you started: https://www.sierrachart.com/AdditionalFiles/NumbersBarsExampleChartbook.cht You will find the instructions for how to use this Chartbook here: Chartbooks (Workspaces): Using a Chartbook Provided by Sierra Chart Support And finally - be aware of the following page which has other examples of Numbers Bars setups that you can use: Additional Files (Study Collections, Spreadsheets, Chartbooks) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
