Date/Time: Sun, 02 Feb 2025 18:04:50 +0000
Transferring Sierra Chart Settings and Data From Existing Installation to New Installation
View Count: 557
[2019-10-01 17:52:55] |
User568537 - Posts: 21 |
Hi can I apply the instructions of Transferring Sierra Chart Settings and Data From Existing Installation to New Installation to transfer settings from a 32bit 1941 version to a 64bit latest version? |
[2019-10-01 18:41:10] |
Yes those are the correct instructions.
