Date/Time: Sat, 04 May 2024 07:42:58 +0000
Trade and Current Quote Symbol Issue v1992
View Count: 526
[2019-10-01 15:05:02] |
Marmany - Posts: 303 |
When Trade and Current Quote Symbol was set to a different value than Symbol in Chart Settings panel and Symbol was changed, in previous versions the Trade and Current Quote Symbol window went blank. In current version this is no longer the case the Trade and Current Quote Symbol retains the different value and strangely, symbol linked charts now also pick up the different symbol in Trade and Current Quote Symbol window. Please advise |
[2019-10-01 17:47:40] |
You need to manage the Trade and Current Quote Symbol yourself fully. It is not going to automatically clear any longer and it is copied when using Chart Linking and using the Symbol option. But we will see about adding a separate linking option for it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-01 17:48:56
[2019-10-01 18:18:45] |
I can clear the Trade and Current Quote Symbol in a study by setting sc.TradeAndCurrentQuoteSymbol = "", however the linked charts still pick up the symbol from the previous setting in Trade and Current Quote Symbol. It will be of great help if you can add a separate linking option for Trade and Current Quote Symbol. |
[2019-10-30 14:48:06] |
Just updated to v2005 and note that option to use a separate linking option for Trade and Current Quote Symbol is not yet available. Will you be able to add this at some point? Please advise |
