Date/Time: Thu, 02 May 2024 07:09:14 +0000
session horizontal lines
View Count: 879
[2019-10-01 08:23:53] |
User884550 - Posts: 149 |
is it possible to draw horizontal lines that would be extended for 1 trading session only?
[2019-10-01 12:42:50] |
This can certainly be done manually by using the Horizontal Line tool and cutting the drawing: Chart Drawing Tools: Cut a Drawing What we will do though is add to the Line study a Number of Days to Calculate Input. This will be out in the next release. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-02 19:40:50
