Date/Time: Sun, 02 Feb 2025 17:59:47 +0000
restoring my customized control bar
View Count: 775
[2019-10-01 06:15:15] |
fraalbe - Posts: 12 |
Hello, I customized my control bar in the past. Now I started SC new and I had to reload the chartbooks. All is fine, except the customized control bar. How can I load the old one again? In "Window/control bars/1-8" all control bars are default/empty... Regards Frank Date Time Of Last Edit: 2019-10-01 07:23:35
[2019-10-01 18:43:21] |
If you have the previous installation of Sierra Chart, then you can copy the file named sierra3.cfg that is in the main Sierra Chart folder, from the old installation to the new installation. Otherwise, there is no way to get the old control bar setup that you had. You would have to remake them. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
