Date/Time: Thu, 02 May 2024 10:08:05 +0000
Quote Board - How to make a Volume Study
View Count: 666
[2019-10-01 01:36:53] |
User149065 - Posts: 12 |
I would like to define average daily volume, weekly high Volume , monthly high volume and yearly high volume for CL, ES and NQ and use them on the quote board. As it is I see only a Volume column. How can I do this?
Date Time Of Last Edit: 2019-10-01 01:37:48
[2019-10-01 08:36:12] |
User907968 - Posts: 802 |
Did you try to use a 'Study Summary Window' instead? Study Summary Window |
[2019-10-01 10:36:48] |
Yes you need to use the Study Summary window for this: Study Summary Window Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
