Date/Time: Thu, 02 May 2024 01:11:21 +0000
$tick
View Count: 575
[2019-09-30 22:27:15] |
User223358 - Posts: 6 |
Hi, I am not able to replay the chart $tick, I am doing something wrong or it is not doable? Thanks, Yvan |
[2019-10-01 10:21:24] |
That is not the correct symbol. The correct symbol is TICK-NYSE and more information is on this page: Sierra Chart Market Statistics Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
