Date/Time: Thu, 02 May 2024 02:01:43 +0000
SC data feed
View Count: 596
[2019-09-30 19:13:03] |
User929084 - Posts: 60 |
Hi. Right now I'm with AMP Global and use their free Sierra Chart package with CQG data feed. I would like to compare CQG with SC data feed. Mainly cumulative delta study with both feeds. I tried to do that with Sierra Chart historical data service as described here on this site, but the option to use SC Data - All Services is not enabled on package. I trade NQ and ES. What can I do to try SC data, could even be historical ( assuming there's no differences between historical and real time ). Thank you. Date Time Of Last Edit: 2019-09-30 19:14:51
[2019-09-30 21:31:16] |
What you need to do is use the Denali Exchange Data Feed: Denali Exchange Data Feed This can be activated, on your Sierra Chart account. The setup instructions are on the page linked above. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-30 21:31:51
