Date/Time: Wed, 01 May 2024 23:10:42 +0000
610 TICK CHART
View Count: 1017
[2019-09-30 19:09:38] |
User317484 - Posts: 15 |
I AM WORKING WITH SOMEONE THAT IS USING NINJA TRADER AND THINK OR SWIM THEY ARE USING A "610 TICK CHART" I WANT TO MAKE SURE I AM SETTING UP MY CHART THE SAME AS THEY ARE I HAVE GONE INTO "NUMBER OF TRADES AND SELECTED 610 DO YOU THINK THIS IS CORRECT OR SHOULD I BE USING A DIFFERENT BAR PERIOD TYPE OR OTHER SUGGESTION ? THANK YOU |
[2019-09-30 19:37:11] |
Refer to this page: Number Of Trades, Volume or Range Bar Charts Do Not Match Setting or Are Not Accurate or Are Inconsistent Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
