Date/Time: Thu, 02 May 2024 03:57:49 +0000
Control Bar - Trade Window Configuration Button
View Count: 666
[2019-09-30 19:07:47] |
lpfin123 - Posts: 59 |
Good morning, I'm trying not to use the Trade Window and use shortcut buttons on the Control Bar instead. I've manage to use the "Trade Window Configuration" buttons, which are working fine. However, when I select them, the change is made (I've check on the Trading Window), but the button is not "pressed", which makes it impossible for me to know which configuration is selected at the moment. When a Configuration is selected, could you make the button looks like it is pressed? Thank you, |
[2019-09-30 20:48:15] |
We understand what you mean but this is inherently difficult to do reliably.
