Date/Time: Thu, 02 May 2024 04:29:57 +0000
Title Bar contains nonsense characters
View Count: 483
[2019-09-30 18:07:15] |
User807771 - Posts: 12 |
In the Title Bar - after the Title Bar Name, Symbol, Range and Description, I have a bunch of characters (e.g., 4444444444444444) in the title bar. I cannot find any settings, other than the "Title Bar Name" where I can modify/remove the random characters.
TitleBar.png / V - Attached On 2019-09-30 17:54:53 UTC - Size: 4.37 KB - 187 views Attachment Deleted. |
[2019-09-30 18:24:30] |
This is because those characters were typed into the chart. Simply press the Escape key when that chart is active.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-30 18:25:11
