Date/Time: Thu, 02 May 2024 00:52:10 +0000
Fib Retracement - How do i make it move automatically with time?
View Count: 559
[2019-09-30 16:35:48] |
maddy91 - Posts: 11 |
Fib Retracement - How do i make it move automatically with time? I have to manually move it. I dont see anything in tools for this price retracement details. |
[2019-09-30 21:35:39] |
As a Drawing Tool, this will not adjust with time, as it does not have a way to recalculate the information. Refer to the following study that will allow you to create Retracement lines based on the bars: Auto Retracement/Projection Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
