Date/Time: Sun, 24 Nov 2024 21:34:27 +0000
Intraday Update File list
View Count: 1245
[2013-12-13 15:52:57]
User39772 - Posts: 311
I use a quote board and all of the symbols in the quote board are also in the file update list.
When I step trough the symbols in the quote board I can see how every single symbol is updated
after I selected it and it takes some time for the update what i tried to avoid with the file update
list. Any hints or comments how i can achieve that the quote board symbols are up to date before
i click on them ?
[2013-12-13 18:57:51]
If the exact same symbols are in the Intraday File Update List, the data has already been downloaded and definitely will not occur when you select the symbol on the Quote Board.
We assume what you are seeing is just the loading of the data from the local chart data file itself.
We tested this and it does work properly.
Date Time Of Last Edit: 2013-12-13 18:58:14
