Date/Time: Thu, 02 May 2024 04:44:14 +0000
Upload a saved chartbook setup.
View Count: 542
[2019-09-30 13:01:40] |
User420291 - Posts: 44 |
Good morning. I had saved a chartbook and when i try to open i get only the background on the screens, but no information. I had attached the file i´m trying to open. Any idea why isnt loading? Thank you. |
Crude Oil Setup.Cht - Attached On 2019-09-30 12:56:16 UTC - Size: 1.63 MB - 228 views |
[2019-09-30 15:26:19] |
Make sure the symbols are matching the current service by selecting this command: Edit Menu: Edit >> Translate Symbols To Current Service I am able to load the chartbook without any problems. There are about 10 charts with a number of studies along with Continuous contracts and lots of data to load, so it took about 10 minutes to load up on my system without any previous CL data already stored. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-30 15:26:55
[2019-09-30 16:47:11] |
Its true, the problem was that. I changed the symbol and now its working fine.
