Date/Time: Thu, 02 May 2024 06:12:31 +0000
Volume Average
View Count: 587
[2019-09-30 00:06:17] |
John Ara - Posts: 125 |
Please let know how I can have 'X=Volume Average of last 15 minutes' and how to compare X with average X of last month? I prefer to have it in bar format? Thank you. |
[2019-09-30 09:19:34] |
NotIll - Posts: 118 |
Maybe you could take a look at the ''relative volume''study and see if you can manage with that. I think you might. Relative Volume Good luck and have fun. |
[2019-09-30 11:41:47] |
For this you will want to use the Relative Volume study: Relative Volume Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
